It is currently Tue Sep 16, 2025 2:27 pm
PostPosted: Fri Aug 12, 2022 11:55 am
First name: Jon
Last Name: Snider
City: Colorado Springs
State: Colorado
Using the Model Machines, or the Proxxon mini saw, and the .023” kerf blade, does anyone feel the need for blade stabilizers to ensure no wobble? Jim Byrne doesn’t sell them.
P.S. I tried the search function. Using the “+”s and other Boolean tomfoolery, but couldn’t eliminate the hits for each word separately. Admittedly need my kid’s help but they’re out of town :)
Any other advice on cutting fretboards with this tablesaw would be great.
Jon
PostPosted: Fri Aug 12, 2022 2:06 pm
I've used a Proxxon FET table saw to cutting fret slots for several years with a 63 mm diameter slitting saw blade and have no need for stabilizers
These users thanked the author Colin North for the post: Pmaj7 (Thu Sep 22, 2022 11:20 pm)
PostPosted: Sat Aug 13, 2022 7:51 am
You can make blade stabilizers out of thin plywood or aluminium using hole saws and an appropriate sized drill bit. On my home made saw and with the thin blades I use I have noticed some blade flutter as the blade enters the cut, so I trim the board to size after slotting. I should add some stabilizers, but so far, trimming after slotting has worked for me.
PostPosted: Tue Aug 16, 2022 8:54 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
yes you need stabilizers
Do a web search you should be able to get some. Mine stop just short the blades teeth.
Amanda Tool STF-4 stabilizers- 5/8" bore
Mike Collins
PostPosted: Tue Aug 16, 2022 9:53 am
I don't think 4" blade stabilizers will fit on a proxxon blade or the Model Machine.
PostPosted: Tue Aug 16, 2022 12:21 pm
Is that a knock off brand from the land of the panda? Spell check at work again! laughing6-hehe
PostPosted: Wed Aug 17, 2022 8:33 am
Last Name: Collins
City: Argyle
State: New York
It's AmanaTool STF-4stabilizer 5/8 bore
SORRY!!
Mike Collins
PostPosted: Wed Aug 17, 2022 8:51 am
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
Lee Valley Tools also sell blade stiffeners, go to the web site and search for “ Blade Stiffeners “.
At least they show them on the Canadian web site.
PostPosted: Wed Aug 17, 2022 11:30 am
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
If you know the dimensions of the stabilizers you want, a machine shop can make them for you. Machine shop work usually costs a bit more than a manufactured product, but you can have exactly what you want. And, the machinist often enjoys weird projects.
These users thanked the author bobgramann for the post: Pmaj7 (Thu Sep 22, 2022 11:29 pm)
PostPosted: Wed Aug 17, 2022 2:01 pm
Brass is another metal easily cut with a hole saw and probably available at a hobby shop in a reasonable thickness. It may be difficult to find an off the shelf stabilizer with a 10mm arbor and the proper size. The shop made wooden stabilizers I have used worked fine, but brass or aluminium would not be any more difficult to make them from.
PostPosted: Wed Aug 17, 2022 4:26 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
forest saw blades sell 4, 5, 6" stabilizers
Mike McNerney
PostPosted: Wed Aug 17, 2022 4:34 pm
your .023 kerf will limit the kerfed lining to bend I see issues ahead. especially with cutaways and 000 upper bouts
PostPosted: Thu Sep 22, 2022 7:52 pm
First name: Jon
Last Name: Snider
State: Colorado
Fretboard kerfs John, not kerfed linings. Thx
PostPosted: Thu Sep 22, 2022 9:36 pm
First name: Tom
Last Name: Rein
City: Saline
Not sure if you already own a mini saw. The Stewmac circular saw blade for fret slotting is great. Works like a champ on my 10" table saw. No stiffeners required.
Stay with the happy people.
--Reynolds Large
PostPosted: Thu Sep 22, 2022 10:04 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
I think Clay is right. Just make your own. Wood, aluminum, brass. I use 5" slotting blades that can be found in places where they sell supplies for machinists. You can get them in any thickness you might want. I use .023, .027..057 blades for various projects. 5" blades work just fine on my 10" table saw, for fret slotting and making kerfing. I stack 4 or 5 of them together, with wood spacers in between, to make kerfing go faster.My stiffeners came from the old Sears store. What a bummer it was for us to lose that store in our town!
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
PostPosted: Thu Sep 22, 2022 10:48 pm
I think the Model Machines and Proxxon saws can take up to 3 3/8" blades - the same as the Makita battery sawblades I use on my home made saw except with a smaller 10mm arbor hole (the cheaper Makita blades could probably be used with a bushing). You probably want to make 1 3/4" diameter blade stiffeners with a 2" hole saw, and then bore out the center hole with a 10mm drill bit.
Like Bob, for cutting kerfed linings I will place several saw blades with spacers on the arbor of my 10 inch saw and cut multiple kerfs with each pass. I like the 7 1/4 inch diablo blades because they are thin kerf and have a coating that reduces the friction on the blade. Not sure if you could put more than 1 blade on the Model Machines or Proxxon saw.
Users browsing this forum: No registered users and 64 guests
